Resetting all AVIC's
By vspc2nr · Feb 19, 2007in Problems/Troubleshooting💬 11 posts👁️ 2,996 views
Posted Feb 19, 2007 · 02:19 UTC#1
Any one got a way to reset my N1 from my 60 back to 40?
Posted Feb 19, 2007 · 03:30 UTC#2
There is no way to change your unit back to the 40mp discs. Even if you were to get your hands on the olds discs, it would not accept them because you have a newer version of maps. Why would you want to downgrade anyway?
Posted Feb 19, 2007 · 04:50 UTC#3
I have both disks(original). I dont want to do the solder bypass and i wanted to try the 60 map disk. It suks cause it still has the same maps and doesn't even have my work as a POI(Best Buy). And i rather watch my movies and still have the same map rather than not watch movies and still have the same maps.
Posted Feb 19, 2007 · 05:27 UTC#4
yeah there is no way you can revert back. Soldering isnt hard. Where is the link to the hack?
Posted Feb 19, 2007 · 11:05 UTC#5
I thought if you went into the service menu, you could erase the entire flash and reinstall software on the Nx/Dx series?
Posted Feb 19, 2007 · 19:00 UTC#6
^^exactly my point. I tried to reset everything in the first page menu but it still has some 60 left in it so it will load and boot the 40 map but at the end it still wants the 60 map. Does anyone know what else to flash/reset.
Posted Feb 19, 2007 · 22:55 UTC#7
Go to 2nd page of service menu,
Use "Program Forced Write" and have ur 40 disc in the dvd drive.
Pick which programs you want to write, and it'll tell you your current version and the version on the disc you have inserted. Once you've selected everything it'll tell you to push the "NAVI" button to write the programs to memory, by "NAVI" it means hit the POS button. I usually force write the GPS application, and two of the other programs in there, but I mean you could do all of them and it wouldn't hurt. Once they're all done loading, you can go back to page one and clear the backup data, it'll restart the unit, then you can press the reset button and it'll start everything back up again, your 40 discs will be ready to use. There's better instructions somewhere around here if u use the search.
Posted Feb 20, 2007 · 06:34 UTC#9
that's one of them, yes. The original I believe was a link to eatmorepork.com
Posted Mar 20, 2007 · 23:15 UTC#10
where is the reset button on n1? trying to get back to old disk.since installing the 60 cant watch dvd any more.never would have put disk in.
Posted Mar 20, 2007 · 23:58 UTC#11
It's the indentation on the face.
