x910bt volume control causes radio to jump presets
By gex598 · Aug 24, 2013in Problems/Troubleshooting💬 3 posts👁️ 1,552 views
Posted Aug 24, 2013 · 19:34 UTC#1
Hello everyone this is my first post here! I just purchased a new to me car and it has a x910bt in it. When I raise or lower the volume it causes the radio to cycle through the presets, if it has an SD card it will cycle folders. The volume will raise and lower, it just causes the other unwanted behavior. The unit says its firmware is 3.02.
Posted Aug 29, 2013 · 04:41 UTC#2
sounds like the multi-function button (volume control among other things) is broken, either that or your not just turning it, your also tilting it one way or the other...
Posted Nov 08, 2015 · 06:10 UTC#3
Does your car have the steering wheel control ?
Maybe your module is causing it
