Hello all once again!
I am still working on my X920BT that was bricked during a firmware update sent to me by Pioneer. Since then I have managed to get it to respond to a number of attempts, bricked it numerous times and recovered it to a point where I can reliably get it into test mode without it shutting down on its own in the middle of making changes. I can also get it to recognize programs such as Condi's Hack Mode, Super Test Mode and that's about it.
During startup it will go to splash screen and then go black with the words Program Startup Error. It will allow me to put it in test mode and from there I have full access to all files. I have done a number of things to attempt recovering the unit to a point where I can use it once again but no luck. My ultimate desire would be to update the unit to something above 2.0.
I believe I need to find a way to rewrite all the files on the unit to start fresh. I am not sure if this is even possible so suggestions are welcome. If I have already tried a suggestion, I will let it be known. I warn though, I have tried so many different options that its getting discouraging. It acts like the Cardinfo file is not working as not one single update has worked. It also will not start an upload on its own and requires me to go into test mode to physically copy and paste each file. As mentioned, the only files that seem to work on their own and without me doing anything are the couple in the first paragraph.
You help is greatly appreciated!
Chris
