need help with DA100 and iPhone 5
By vazzzovsky · Sep 03, 2013in AppRadio, AppRadio 2, AppRadio 3💬 12 posts👁️ 1,533 views
Posted Sep 03, 2013 · 17:13 UTC#1
Hi everybody!! Sorry for my bad English, but i need ur help!!
Im from Russia and AppRadio isnt popular, so we dont have enough information and forums about.... but...
i bought DA100, upgradet it for 8.30
also i bought hdmi hi speed cable, connected it to DA100, connect USB to Lightning cable...
also i bought Lightning to HDMI adapter.
i connected all this stuff, install CarMediaPlayer, AppRadio for my iPhone5 (6.1.2 jealbrake), but it dont work!!! Nothing happens at all.. i only see blue line on my iphone for 10 seconds (like i turn on Modem on my iPhone)..
in the settings i set up iPhone Digital AV....
But when i connectec ipod (lighting without hdmi), i can see music etc..
I dont know what to do.. pls help me (
Posted Sep 04, 2013 · 01:35 UTC#2
If you are having Jailbreak problems, I would check the forums at http://modmyi.com
I'm not quite following but I'll throw out a few things.
Did you pair the iPhone 5 to the AppRadio successfully?    As a troubleshooting test..........
Can you press the Bluetooth button on the main home screen of the AppRadio and then play music successfully via any iPhone app? (with no wires plugged in, A2DP only)
Bluetooth needs to be working 100% regardless if the cable is plugged in or not.   All iPhone 5 remote controls are done over bluetooth
Posted Sep 04, 2013 · 05:30 UTC#3
thanks.. i fixed it - problem was with HDMI cable - i changed one and AppRadio now works correctly...
but when my iPhone connected through Bluetooth and Lighting (usb+hdmi) ipod app is unactive... also unactive picture setting in Settings menu... but i want to correct my display settings like brightness, colors etc... how i can fix it?
Posted Sep 04, 2013 · 09:05 UTC#5
It's under settings, just be careful when you scroll down.   You actually SKIP over some the options if you touch it wrong. (it will jump a page or more at time)    I had the same problem and couldn't find the display setting at first.   I was then very careful to scroll slowly and found the display area to change brightness and the dimmer options for when car lights are on/off etc.   Take your time and look again it's there.  (I missed it the first time and got frustrated as well)
I also couldn't figure out how to set the time right away.   You press and hold the : between the hour and minute for 5 seconds
Edited Sep 04, 2013 by JazJon
Posted Sep 04, 2013 · 12:22 UTC#6
i tried about 10 minutes =)) but cant find nothing except "Picture Adjustment"...
But this ine gray and unactive..
i did this with iPhone (Lighting HDMI and Bluetooth) connectet..
Posted Sep 04, 2013 · 21:06 UTC#7
Did you pull the parking brake?
Posted Sep 05, 2013 · 04:34 UTC#8
Oh yeah I forgot that not everyone has a parking break bypass setup. (much easier)
For default installs, It makes sense that certain settings are not available unless the parking break is on.   It should un-gray out after it's pulled yeah!
Posted Sep 05, 2013 · 09:21 UTC#9
is it green one cable?? nope =(
Edited Sep 05, 2013 by vazzzovsky
Posted Sep 05, 2013 · 09:45 UTC#10
i ll fix it, but.. when my phone connected through bluetooth and i turned on music - its playing through iphone^ not through DA100... how i can play music through bluetooth without lighting?
Posted Sep 05, 2013 · 09:48 UTC#11
There is no BT audio on the DA100.
Posted Nov 06, 2013 · 04:21 UTC#12
i have a little question - im trying to connect my ipod nano (7th gen) - i connect it through lighting - USB Cable (without lighting HDMI adapter)&& But my iPOD APP in AppRadio is not active.
When i opened AppRadio Mode (iPhone Digital, Other) - its grey and not active too.. i cant change Mode of My AppRadion&& Why? Pls help me&&
