Ejecting SD card/ DVD/ CD....Not quite right
By giblets46 · Sep 06, 2013in Problems/Troubleshooting💬 2 posts👁️ 619 views
Posted Sep 06, 2013 · 16:24 UTC#1
Hi,
I have an F-30bt (now updated to F40bt, but neither has effected the problem).
When I eject an SD card, I press the OK button nothing happens, I have to use the tilt function to shut it, also tried the eject button nothing, end up having to use the tilt button.
Occasionally when open it will restart, or I press the eject button, and it tries opening again (despite being in the open position), it sort of jams at the extreme and stops itself...it then closes fine.
Edited Sep 11, 2013 by giblets46
Posted Sep 11, 2013 · 20:52 UTC#2
After the unit refused to eject a DVD I got a bit worried. Reading up, someone mentioned a power off reset ( ie battery disconnect) solved he issue immediately. Seems the unit thought the face plate was in a slightly different position and not fully open.
