Installing a Z1 in a 2007 Honda Element
By subie · Feb 19, 2007in General💬 15 posts👁️ 3,585 views
Posted Feb 19, 2007 · 20:11 UTC#1
I have seen some people mention that a Z1 won't fit in a 2007 Element. Is this true? It appears that it fits in 2006 and earlier Elements. Is there an install kit that would be needed? I'm guessing I can find the VSS wire pretty easily, but if anyone knows of anything tricky I'd appreciate it. Thanks for your help!
Posted Feb 19, 2007 · 20:52 UTC#2
you have two cars?
Posted Feb 19, 2007 · 21:50 UTC#3
I was told some back straps and trim piece would be all that you need. I asked this question a few weeks ago.
Posted Feb 19, 2007 · 21:59 UTC#4
If your Element is anything like the Ridgeline, there are more than two places where you can tap the VSS. You need to make sure you get the right one. One of the areas I tapped was the in the engine compartment and the speed pulse from that location was too fast. I was getting error messages from the Z1. I ended us using the VSA wire on the passenger kick panel area and that worked. Hope this helps.
Posted Feb 20, 2007 · 05:03 UTC#5
The Z1 does fit in a HONDA 2007 Element . I have mine in But there is a vss issue that i cant find the wire to connect to and the one someone has suggested, A18 does not work ! HELP PLEASE PLEASE
If possible would any one have or know where to hook up the vss on a element 2007 I have tried the blue wire at a 18 .
Someone just wrote about a ridgeline kick panel. and works at honda could you find this for me please the blue wire at the a18connector gives us the fault also . I need some where else to hook up
Things have changed for the 2007 model. As the above post said the used the countershaft for a speed reference. The speedometer is controlled by the ECM/PCM.
Speedometer
The speedometer is controlled by the 5V stabilize
circuit/controller area network controller built-into
the gauge control module. The 5V stabilize
circuit/controller area network controller receives
vehicle speed information from the ECM/PCM
through the fast controller area network transceiver
via the multiplex integrated control system. The
ECM/PCM receives vehicle speed information from
the output shaft (countershaft) speed sensor.
(It looks like the connector A18 COUNTERSHAFT SPEED SENSOR may serve your purpose.) We tried it does not work I am getting the error messages from the Z1.
attachment.pdf
CW0707201093A-1.pdf
VSS WIRE 2007 ELEMENT.doc
Posted Feb 20, 2007 · 17:40 UTC#6
Yes, I would stay away from the countershaft speed sensor. I used that on my Ridgeline and got way too many pulses (I was getting thousands going less than 5mph)...you will get errors from the Z1.
Posted Feb 20, 2007 · 18:35 UTC#7
what did you use on the ridgeline , which cable ?
Posted Feb 21, 2007 · 01:02 UTC#8
Would anyone know where the vss wire is in a Honda element 2007 year?
Posted Feb 21, 2007 · 01:56 UTC#9
um, i remember something about behind the headlight, in plug.. blah blah.. blue .... cant say for sure though
Posted Feb 21, 2007 · 03:34 UTC#10
you have two cars?
My girlfriend has an element and I am looking into a gti...
Posted Feb 21, 2007 · 19:40 UTC#11
4
Posted Feb 21, 2007 · 21:10 UTC#12
5
Posted Feb 21, 2007 · 22:24 UTC#13
:? you typing to me ?
Posted Feb 21, 2007 · 22:45 UTC#14
3
Posted Feb 21, 2007 · 23:33 UTC#15
I thought we were counting.
