Please help with bypass after install is complete
By Steveomatic · Sep 18, 2013in Hacks/Mods💬 7 posts👁️ 2,305 views
Posted Sep 18, 2013 · 23:51 UTC#1
Hi,
This forum looks great and I plan on being a contributing member. I have a question. I have an Avic-x850bt that was professionally installed in my 2013 Mazda MX-5 Miata. I want to perform the Parking Break Bypass but I am hoping that I do not have to remove the HU to make it happen. The green wire has been secured to the parking break. Is there a way to simply remove this from the parking break and somehow perform the bypass without removing the HU?
Thank you for all suggestions and feedback.
Steve
Edited Sep 18, 2013 by Steveomatic
Posted Sep 19, 2013 · 11:27 UTC#2
Steve
Not unless you plan to wire the P brake wire to a switch. If you want an automatic bypass you are going to have to access the harness on the rear of the unit and I don't see how thats going to happen without removing the unit.
Posted Sep 19, 2013 · 15:53 UTC#3
VBLUE42, Thanks for the reply. I saw an old post about mofifying an .ini setiing and uploading that to the head unit. Does that still apply to the Avic-X850bt? If I ground the parking break wire from the HU at the parking break and then do this .ini trick will that work?
Thanks,
Steve
Posted Sep 19, 2013 · 16:34 UTC#4
That's for the first gen X series and doesn't apply to the current series if units. The bypass proceeded for the 850/950 is present on this forum.
Edited Sep 19, 2013 by VBLUE42
Posted Sep 19, 2013 · 17:19 UTC#5
Thak you for the replies. My last question is since I already insalled this I prefer to use the switch. I did try to just take the parking break green wire directly to ground by the parking break. This works until I start driving over 10-15 mph. If I do the switch (toggle) do I simply put the green parking break wire and the ground to the switch? Can the ground be coming directly from the chasis or does it have to be a ground on the radio harness?
Why will the toggle work but not just grounding it. What is the differene?
Thanks so much for all your help!
Posted Sep 19, 2013 · 22:33 UTC#6
Actually my mistake, being this is an AVIC unit you will need to do the two wire bypass so again you will need to remove the unit. There are others that claim a one wire bypass is all thats required by grounding a wire other then the P brake wire but that method seems to be inconstant. Regardless you're going to have to remove the unit.
And a ground is a ground. Just make sure it has a good connection.
Posted Sep 20, 2013 · 00:03 UTC#7
All good. Made the connections correctly and I am up and running, thanks. Luckily I barely had to pull the head unit out to reach everything.
