Hi all, my original antenna wire ripped away from the magnetic part of the antenna and I lost Sat signal, obviously. Well before I had a chance to buy a new one on eBay, I found a brand new one at a thrift shop for $5. I figured I'd give it a shot. It's a Term XMicro2 for XM. I figured they were all the same even though the plug was slightly different. I spliced the old plug onto the new one. The D2 found the antenna but shows no satellites. Is there anything else I need to do to reset it? I puled the power plug off and went into the calibrate service menu and tinkered around to see if there was anything. Could it simply be not the right antenna. The map shows the same location as it showed since the original antenna broke, and that is somewhere in NYC. I line outside of Philly so I'm not even remotely close.
Posted Sep 22, 2013 · 19:05 UTC#1
