appradio harness vs x940bt
By m.a.s.e · Sep 28, 2013in AppRadio, AppRadio 2, AppRadio 3💬 4 posts👁️ 1,083 views
Posted Sep 28, 2013 · 21:03 UTC#1
Hi guys. U have currently installed the x940bt in my car.
I now ordered the appradio3 and I was wondering.... Is the harness the same between the two? If I just unplug the harness from my x940bt and attach it to the ar3 will it work or do I need to completely remove the harness and redo the installation? I already have everything connected with the wheel remote (PAC PS) and the stock Rockford fosgate system adapter to after market radio (axxeon)
Thank you
Posted Sep 29, 2013 · 01:40 UTC#2
it's probably not the same.  U don't need to mess with the PAC SWI-PS wiring.
Posted Sep 29, 2013 · 01:42 UTC#3
I see you also posted the question in the appradioworld forums as well, no answer there either, i dont know if Pioneer standardizes there plugs or not but you probably wont know until you get the two side by side to compare.
please update this thread when you find out so people can use your prior experience with these two radios if they decide to switch as well.
Posted Sep 29, 2013 · 02:37 UTC#4
Will do...
i REALLY hope its gona be that easy as plug n play....
i really dont feel like disconnecting everything and reconnecting again :)
