Appradio 3 shrinking apps
By justinmoir · Oct 16, 2013in AppRadio, AppRadio 2, AppRadio 3💬 17 posts👁️ 3,874 views
Posted Oct 16, 2013 · 21:53 UTC#1
Hi there,
I have recently installed a DA 110 appradio3 in my car, everything was great until last week when I was using Navfree and waze, it starts off full screen then shrinks down so there is a black border about a cm thick around the whole picture??
It also asks me to allow appradio to connect to my iphone 5 after each call?
Shrinking picture also happens when playing netflix etc!???
Anyone got a fix or had the same issue?
Cheers,
Justin
Posted Oct 17, 2013 · 01:52 UTC#2
Same issue. Started after ios7 upgrade for me
Posted Oct 17, 2013 · 14:43 UTC#3
Same for me after iOS7.
Posted Oct 17, 2013 · 17:24 UTC#4
Same issue for me (IP4S on iOS7 with SPH-DA100).
I used to occasionally get this with earlier iOS versions. I posted here about it and somebody said it might be correlated to receiving emails. I have noticed the screen shrink right after receiving an email, but I believe that the shrinking is more random than that. The weird thing is that this weird behavior would stabilize over time, so I never really cared too much.
But now it happens pretty much every time I use App Mode on iOS7. This time around it's much more annoying to me.
Does anybody know how to report bugs to Pioneer? They sure do make it difficult.
Posted Oct 17, 2013 · 17:44 UTC#5
Thats because they don't seem to want to hear it from users. They seem to have the attitude that they can find all the bugs.
Edited Oct 17, 2013 by VBLUE42
Posted Oct 17, 2013 · 21:12 UTC#6
This is an issue with the OS. Any display has to deal with overscan(displays cutting off the edges of the signal. It's an old tv analog signal problem that has lingered). For whatever reason apple doesn't let you  control overscan protection on iPhones and iPads while they do let you do it with the apple tv. iDevices default to overscan protection on. The problem here is that Pioneer doesn't use overscan on their display. Again, ancient tech leftovers. Why use it? So they put in their APIs code to tell appradio apps that they need to block overscan protection when sending to appradio. This used to work... until iOS 7. Whenever an app shrinks the HDMI adaptor has deemed overscan protection necessary for the video source, overriding the Pioneer request to not overscan to compensate for Apple's silliness, and it shrinks the signal to compensate.
Apple needs to let us turn this ancient protection system off. That would solve all problems.
Posted Oct 21, 2013 · 19:07 UTC#7
Hey guys,
Had the same issue. This may or may not solve it. But I havent had the shrinking in over a week (and it was doing it everyday for me) All I did was while the phone was connected to the Appradio I went to Settings-General-TV Out and switched "Widescreen" off. It seems even when switched off the unit displays the video in the proper aspect ratio but the overscan issue doesn't occur.
**UPDATE** Nope still fucking does it. Just was lucky during my drives I suppose.
Edited Oct 22, 2013 by stephen8665
Posted Oct 24, 2013 · 17:17 UTC#8
I updated to iOS7.0.3 and the frequency of this has reduced a lot it seems. I only saw it once now on my iPhone 5.
Can you guys confirm
Posted Oct 25, 2013 · 15:53 UTC#9
No change for me. Waze still shrinks.
Posted Oct 25, 2013 · 22:47 UTC#10
Hey guys,
And this is not even an option in iOS7 that I can find.
Edited Oct 25, 2013 by VBLUE42
Posted Oct 26, 2013 · 20:18 UTC#11
If he has a 4/4s their tv out is analog, hence the setting. The apple HDMI-lightning adaptor has no settings for the user to access.
Posted Jan 21, 2014 · 18:40 UTC#12
I installed iOS7.1 beta 4 on both iPhone 4 and 5 and the great thing is that the shrinking no longer occurs on either phone!
Can someone else confirm?
Posted Jan 22, 2014 · 02:40 UTC#13
I had beta 4 for a little while but my phone wasn't running well on it so I downgraded back to 7.0.4.
Posted Jan 22, 2014 · 13:56 UTC#14
Yup, I can confirm this. Well, it does actually shrink for me when using car media player but then goes back to full size almost instantaneously. Happy days!
Posted Jan 31, 2014 · 00:12 UTC#15
Thanks for this, helpful explanation! Very annoying though...
Posted Jan 31, 2014 · 00:15 UTC#16
Sorry, was trying to quote this...
Posted Jan 31, 2014 · 00:16 UTC#17
For those of us sticking to 7.0.4 so they can use Mike's Appradio Extensions can't update to 7.1 though :( I wonder if Mike could implement a solution in his tweak...
