Has anyone installed the DA110 into a peugeot 3008??
If you have, did you relocate the in dash display for your parking sensors, trip computer etc??
Many thanks,
Justin
Many thanks,
Justin
Hi, i have installed avic z150bh in my 3008 (2009), you dont really need the indash display, however you will loose the visual reverse sensor in the display, but the sound still ring. I carefully set up the way i wanted the vehicel prefs before removing the original radio. You can reset the tripcomputer via the controls on the stearingwheel, and you also loose the USB connection in the centerconsole, its replaced with the one connected in the back of the pioneer. The built in wireless bluetooth mic will also not work anymore. And i lost the steeringwheel radio control, though that worked on my previous clarion unit i had installed before. The outside temperature in the display is also gone. So its a win some, loose some situation. Hj
