Hi all! first off let me thank all of you who have helped me immensly so far: Tillithz, Ducati, Jason, Paisan NYC, OSUV, cntrylvr79, T, aznsmartass24, and all the others, seriously thanks. It's now MY time to ask the stupid questions that you will laugh at me for, but, hey, I might as well ask instead of fuckin up my ride! A lot of what I need to know at this point is vehicle specific, so if you can help, great, but if not, don't worry about it. Tillithz, I know you've answered these questions before, but I will be printing up these responses (if any) to help aid me during install.
again this is for a limited '06 WRX
1. Whats the best way to remove the stock HU? I understand you start through the "shifter", and continue to remove panels, but I can't figure out how to get that started. Many of these plastic clips feel "breakable" and would like to know how to pull them off correctly.
2. The VSS and Reverse are located on the ECU which is on the passenger floor, correct? What exactly do I do to hook those two wires up? Do I just splice into each one of them? If so, what is the deal with the "pins" I'm supposed to remove, I can't quite figure that out.
3. The bypass. I have a post july unit so I won't need the flasher, and I have the Bluetooth update CD, BUT, I'm still a little foggy on what are the EXACT two wires that need to be grounded. After I HAVE found the two wires that need to be grounded, how do I do so? Again, It's the "pin" thing I don't understand. If they need to be grounded can't I just hook them up to a piece of grounded metal?
4. If you have any recomendations for running the wires from my backup cam (rear lisence plate) up to the front? People have removed seats for this and I'm checking to see if that's really nessesary.
Obviously pics can explain a lot of this very well, so If anyone has any please post, It could save a lot of dialog but just pionting to the correct wire (or PIN!!)
Thanks in advance for any responses, And I'm sure I'll be speaking with all of you more once I actually have this thing installed. I'm all about the customizations and stuff like that. Jokes are always appreciated!!
