OK...How do I get the new update on my unit when there is no SD slot?? (Mine is thew one without the dvd player)..Thanks!!
Appradio 3 sd for update....
You need to use a usb flash drive in order to update it. The one thing im not sure about is whether or not you can use the USB port on the back, or if you must have the special Pioneer cable in order for it to work. I tried one USB flash drive and it said the file was damaged. Read online that this is a common problem, that the AR is really picky about flash drives. Anyone have an idea?
You use the USB on the unit.
Where is the USB located??? My unit does not have a flip screen??
On the back.
On my SPH-DA210 I had to use the usb cable attached to the unit after formatting the USB drive to FAT (it did not like FAT 32).
I got this to work last night after using a SD memory card from a camera i have. the USB thumb drive wouldn't work for me. Can't really tell any difference between the versions, I still don't get any audio via App Radio, only Bluetooth. ![]()
And how did you use an SD card on a unit with no SD card slot?
Sorry, I used a USB memory card reader for the SD Card, so in essence, it was a "usb" drive. My normal thumb drive didn't work, so this was my last resort, and it worked!
Yeah I knew that! That was my way of getting you to explain yourself before people started asking where the SD card slot was on their units.
I'm assuming appradio 3 uses USB 2.0 not 3.0 right? I'm going to run an extension cable and some 3.0 ext cables have issues with USB 2.0 devices (from reviews I've been reading). Just want to double check.
