Well this did not go as planned.
I bought a 2007 Denali. Replaced all the speakers, headunit, wiring harness, took out the headunit and put the following in the car
RPTCARSYS-5,
PIOSIRPNR2 Sirius
PIOCDBI100 Blue tooth
PIONDBC1 Pioneer Navigation
PIONDBT1 Pioneer Monitors
MTR993301 Metra Electronics Wiring Harness / Kits PIOAVICZ1 Pioneer Navigation
Ducati's bypass
Here is a list of issues:
1) The only time the center screen comes on is when 1) I'm parked 2) I hit the brakes when I'm moving. Also getting a "parking brake error"
2) Sirius radio unit installed, Sirius activated, all channels show threw the headunit, no songs playing thru headunit. If I change to DVD, i can hear that. I can hear fuzz on AM radio, but no sound when clicking on any Sirius stations.
3) No turn signal, backup sensors, door chimes etc... (should the headunit been removed? or kept in the car hidden behind the Z1?)
4) Wining sound all the time..sounds like engine noise and gets worse as you accelerate
5) Told DEQ-P8000, AXM-P8000 aren't compatible, can't control each other?? So they had to uninstall it. Only could get stadium and other effects like that, no 5.1
6) Can't get local radio stations
7) Composite out to rear display fuzzy on Mirror mode mostly and somewhat on DVD's
The headunit is not square sitting/flat, the right side dips inward
