AppRadio 3 (SPH-DA210) - connection issues`
By joesturbo · Oct 21, 2013in AppRadio, AppRadio 2, AppRadio 3💬 3 posts👁️ 1,469 views
Posted Oct 21, 2013 · 01:48 UTC#1
Hi,
I just bought a new 210 model and I am having problems connecting. I have done the usual steps as found by other threads however my icons for apps never light up.
1. Radio DA210
2. Blue Tooth connects fine (can stream music from Phone)
3. iPhone 4s with IOS7
4. Latest software on radio (version 5.08?)
5. Tested with Bluetooth off
6. using standard cable from Apple to USB connection
7. Using a toggle switch to allow viewing of DVD's.
That is all I think that would help bring some light to the issue.... any ideas? I just got this thing (looks great).
Posted Oct 21, 2013 · 01:52 UTC#2
The unit may be set for an i5 so you need to read your manual and change the settings. And the Apple cable isn't going to work for app mode anyway. The cable you need is on Pioneer's site.
Posted Oct 21, 2013 · 13:04 UTC#3
I did have it set to "Other" in the settings... It is a little confusing as I read in one of the manuals the factory Apple cable should work and so did the place I ordered it from...
but it sounds like no go then...
will have to order the cable.
