Having a few issues with the below instructions, will remove the "Strike Through" once I got the process 100%.
No guarantees for anyone who chooses to proceed as yet.
It is possible to install the firmware for the Australian F940BT available here onto the F930BT
There are a few steps involved in getting this to work:
Download Condi's Hack v1.4 here Run as per instructions here to perform backupGoto "File Maintenance>USER" select all and DeleteDownload Condi's AutoInstall Hack v2.1 here and runSystem will start and display some message about something not found (Can't remember exact text)Follow the instructions for updating F940BT firmware as found here (Follow the Update Navigation part)Update will run and install files, once it restarts (Step 5 of the instructions), remove the SD card and restart unit. By doing this we are skipping updating uCom, not sure what function this performs.Proceed the Update Bluetooth firmware component of the instructions from step 6 of this tutorial.
Your F930BT should now be updated and running the software of the F940BT with updated "AV Source" and connection functions for Apple devices using the Lightning Connector. AHA Radio will also be installed ![]()
