Appradio extentions on iphone 4 (best setup)
By Cameron.CCW · Nov 19, 2013in AppRadio, AppRadio 2, AppRadio 3💬 7 posts👁️ 1,440 views
Posted Nov 19, 2013 · 05:14 UTC#1
http://www.pioneerelectronics.com/PUSA/Car/Accessories/Smartphone-and-iPod-Cables/CD-IU201N
I was using the CD-IU201N connection cable with my phone for appradio extensions but it was way too laggy to use. I was wondering if i used an HDMI adapter for my phone if that would make more responsive.
(would this work better?)  http://www.amazon.com/1080P-Adapter-Cable-iPhone-Itouch-/dp/B00A6Q596I/ref=sr_1_1?ie=UTF8&qid=1384838012&sr=8-1&keywords=hdmi+to+30pin
Posted Nov 19, 2013 · 06:31 UTC#2
The cable has nothing to do with how AppEx works.
Posted Nov 19, 2013 · 21:56 UTC#3
How come mine is so laggy and when i see videos on youtube theirs is like they were playing it on their phone?
Posted Nov 19, 2013 · 22:22 UTC#4
I don't know but AppEx has nothing to do with the cable.
Posted Nov 20, 2013 · 15:55 UTC#5
The iPhone 4 is connected to the AppRadio by a direct connection. Your touch inputs are translated to the phone via the USB data port on your 30 pin port. This is faster, and more responsive than the bluetooth based solution used for the iPhone 5/5s/5c due to the slower data rate of bluetooth and because the Apple HDMI adaptor has lag. You have the fastest interface method for your phone. It may be that your phone is simply slow due to it being a device that is 3 generations old. However, I have not used an iPhone 4 with an appradio, so I don't know for sure.
How responsive are your AppRadio apps?
Posted Nov 25, 2013 · 04:32 UTC#6
very responisve. I think you are right about the 4 being slow...I've watched some youtube videos of people showing off appradio extentions on the iphone 4 and its laggy on theirs too....Maybe its time to upgrade
What iphone are you using?
Edited Nov 25, 2013 by Cameron.CCW
Posted Nov 25, 2013 · 21:01 UTC#7
iPhone 5. Problem is the 4s and up aren't jailbroken in iOS 7 yet. So as such you're stuck without AppRadio Extensions. Also, the 5 and up use bluetooth, so it is going to also be more laggy.
