Screen problems could it be the screws?
By 04gotgoat? · Feb 26, 2007in Problems/Troubleshooting💬 6 posts👁️ 1,169 views
Posted Feb 26, 2007 · 01:29 UTC#1
I am wondering if anyone else has expirienced this situation...
Before sending in my Z1 for service to Pioneer my screen opened and closed fine. After getting it back and installing it this time it seems like the screen will open 3/4 the way and go back up and stop right under the hard drive. Before I try to uninstall the unit as its a pain in with my car...Would the length of the screws effect the opening and closing?
Posted Feb 26, 2007 · 01:36 UTC#2
length of the screws? as in screwing it into the unit?
Posted Feb 26, 2007 · 01:49 UTC#3
right. Can the screws interfere with the opening and closing?
Posted Feb 26, 2007 · 22:04 UTC#4
The screws that screw into the sides of the unit? Yes abosultely they can cause problems if you use screws that are too long. I beleive if you look at the side of the avic it says what the max length of the screws is.
Posted Feb 27, 2007 · 04:13 UTC#5
Happened to me a few times after messing with the din around it.
So what is happening is that the rails which the screen slides on gets a bit stuck on the bezel/din kit of the car.
Temp Soln: When opening/closing, push down on the DIN kit around the unit to create more gap.
Perm Soln: Remove the unit and try to raise it up a bit (you need barely 1 cm more room). So when re-screwing it in place, put upward pressure on the unit itself so it's slightly raised.
* As long as your issue is the same as mine (which it seems like it is), there is nothing wrong with the unit itself. Just a slightly wrong install :P
Posted Feb 28, 2007 · 03:44 UTC#6
Thanks for the reply. That was what I thought may be the prob. I took it out of the trim panel and it is still not oprning. Maybe the rails are bent?? Funny thing is that it goes back into place fine but only after a reset or shutting off the car.
