YouTube on Appradio
By jaguarr · Dec 03, 2013in AppRadio, AppRadio 2, AppRadio 3💬 11 posts👁️ 1,931 views
Posted Dec 03, 2013 · 15:47 UTC#1
Hi,
Is it possible to watch YT on SPH-DA100 ?
if so , how can I do that?
thanks!
Posted Dec 03, 2013 · 20:29 UTC#2
EC Touch will do it. The youtube feature is $2.99 though.
MyPV will also do it, but you have to go off playlists that you make in advance and lots of videos won't play. It also has annoying pop-ups.
Posted Dec 04, 2013 · 08:57 UTC#3
Thanks !
Posted Dec 04, 2013 · 16:04 UTC#4
I use a YouTube app called MxTube. It supports display out so itll work on the appradio. if you have the 5 or 5s you need the lightning to hdmi adapter and an hdmi cable. if youre on the 4s or 4 itll work with the 30pin. the way i get it to work is to click on Apps on the radio and when it prompts to open the app on the phone ignore it so you have a blank screen. then just open up the MxTube and play the vid. it should display to scale on the the radio with no issue
good luck
Posted Dec 04, 2013 · 20:39 UTC#5
You can use the YouTube app on your phone. In fact you can use any video app you want. Just go through the App Mode screen and hit the ignore button to launch the App radio app. Then open the app you want from the phone.
Posted Dec 07, 2013 · 20:13 UTC#6
Thanks,
I can confirm its works , so what the advantage to use the YouTube via 3rd party ?
Posted Dec 07, 2013 · 21:30 UTC#7
The only advantage you get is control from the unit. What you don't get using YouTube through EC Touch is the ability to search for vids which IMO makes the feature completely useless.
Posted Dec 07, 2013 · 22:46 UTC#8
THird party apps that support display out will scale the full screen. And you can control the stream quality.
Posted Dec 08, 2013 · 03:38 UTC#9
Video form the YouTube app scales full screen.
Edited Dec 08, 2013 by VBLUE42
Posted Dec 10, 2013 · 23:48 UTC#10
Noob question - so any third party iphone app that supports fullscreen will work (along with touch on the AppRadio)? Or will it still give you the red X?
Posted Dec 11, 2013 · 03:22 UTC#11
I didn't say anything about touch. No app thats not AR approved will work from the screen of the unit unless you have a jailbroken iDevice and App Radio Extensions installed. Regardless it will still display full screen video on the screen of the unit.
