Hi All,
I am new to this board. I just got a AR3 with FW 8.02. I tried to do the bypass with a relay, but it didn't work. So which bypass should I buy?
Thanks in Advance!
Sappy
Hi All,
Thanks in Advance!
Sappy
Which countries are you in?
European units don't need a bypass. US try here :- http://www.microbypass.com/
THANKS ALOT, I am from CANADA!! in other words, C eh N eh D eh!! lol..
Another microbypass user here, works like a charm. Only sometimes it's greyed out but then I just unplug and replug the phone and all good.
I am in the UK and recently installed my AR3. It doesn't let me mirror my iPhone display when the parking break is disengaged. Do I need a relay to get this functionality?
microbypass :thumbup:
All you should need to do is ground your P Brake wire.
Hi
Go to your local electronics store and buy
push to make switch ( can be any size your fancy or and design ) with 2 terminals
some wire same thickness if you like of the parking brake wire, i bought some 6amp
thats it
attach the parking brake wire to one side of the switch ( by snipping of the blue connector on the brake wire )
attach some wire to the other terminal ( size dependant on next bit )
put the loose wire from the switch to anything metal on the car OR to the black wire on your radio loom ( i did to the loom because my radio bay is encased in a plastic box )
now pop the switch where you like , even leave it inside the dash with the switch pressed in or on
thats it !!
i have app radio 3 with latest firmware
Or if you want a full automatic bypass and don't want to fool with some silly switch get the micro bypass.
switch is a permanent bypass until you choose to turn it off and costs less than a dollar, i bet it also takes less time to do too. It is also illegal to drive whilst viewing video contents , if you see the police looking you can flick the switch to disable from viewing eyes.
Most people don't want to deal with a switch when bypassing their units. And most people won't quibble over 20 dollars for a proper bypass after spending several hundred to a grand on their unit if they don't have to deal with flipping a switch every time they want their units to work.
you don't flip the switch when you want it to work, its permanent !
i pressed mine once on install, dropped it under the dash and thats it job done. i turn the vehicle on & off all day long if i want to and the bypass is there every time all the time because its 100% permanently bypassed.
whoever told you that this bypass needs attention every time you turn the radio on is telling a few fairy tails. Its bypassed until you choose to either remove the switch, turn off the bypass or remove the radio.
Its like a 30 second install and less than a dollar.
The AR3 requires a pulsed bypass that a "once on" switch won't do. Unless you're not in the US. And if thats the case nothing other then grounding the P brake wire is necessary to achieve the bypass.
