Hello Gents,
Can Anyone help to advise correct video file format to be played from USB, SD and CD/DVD on F940BT?
A lot read on other forums, but files (after lot of converts) not readable or jerky.
Hello Gents,
Hi Eiro,
The best advice i can give you is to use this tool http://www.xmedia-recode.de/
I had a thread here too regarding this. I have a F950dab and i had the same problem. Using different converters was a pain in the ass since they all did something to the file which made it unraedeble. Keep in mind that our units have a max resolution av 400x240. Using the xmedia-recode tool , it has profiles for Pioneer units, inkluding 940BT. I use this one to to convert my files and it works flawless. You can use some others tools as well, MovaviConterer was a good tool also , but is not a freeware.
Check ur manual refence table on supported files. Very important that part.
This issues here , is nothing else than crappy codec Pioneer is licensed to use. The limitation av 400x240 is also just another bullshit. The screen support higher resolution, ref DVD movies.
I wish somebody made a player for these pioneer units. One which plays everything without changing files and better handling on fast forward for long mp3 mixes.
Good luck
Thanks, CatalinT!
I'll try today.
Dear CatalinT,
Where is possible to change image size in xmedia ?
Try xvid ( which the manual says is unsupported), only thing that got mine (f30bt) working
