Hi everyone,
I have a F940BT that i tried to update to 5.100 from 4.00. I followed the guide and instructions to the book.
Even followed a video from pioneer in australia. I did the 1. program ucom write and it ran the update twice before coming up with cs err.
I wasn't able to exit out of the update console. In the end i managed to get the head unit to turn off but now it will not boot up at all. No boot logo just a blank/black screen.
Does anyone know what i can do to revive the unit back up please?
Many Thanks
Smurf
Hi all,
I've got the same problem as you...
Bought a 2nd hand avic f940bt.
Installed the 2013 maps (worked perfect after that)
Bought and installed the ui202navi for iphone 5 connectivity
Read that I had to update firmware to 5.1.
Put the firmwared on formatted sd-card
Here I used write all ucom data, instead of write ucom data.
So i saw two rows updating. and it was successful.
Then I waited, and waited... nothing happened... so I thought. ok lets try the "write ucom data".
It started writing again, but repeated it several times with a CS error.
Then the unit would not shut off. at all, not even when I removed the key.
Then I tried to navigate, and when i doubletapped the screen, the unit shut off.
And not it has been staying off since... no life at all.
I tried disconnecting the battery, and checking the fuses... no reaction.
what to do? any suggestions?
Cheers!
