D1 screen not opening
By thegame181 · Feb 27, 2007in Problems/Troubleshooting💬 17 posts👁️ 3,126 views
Posted Feb 27, 2007 · 06:33 UTC#1
Got a question for everyone, my D1 screen has been unable to slide down. Actually it slides down in the morning, gets stuck during the day, and then at night time it will slide down again. Is it because the system gets too hot cause I live in AZ. Any suggestions would be great.
Posted Feb 27, 2007 · 13:24 UTC#2
It's possible that heat may have something to do with it, but, just to be sure, make sure that the mechanismis not hanging up on the dash fascia.
Posted Mar 22, 2007 · 06:10 UTC#3
Still need a reply to my question.
Posted Mar 22, 2007 · 14:41 UTC#4
How hot does it get? Search for the operating temperatures. I know it does not like near freezing temperatures, but im sure its the same for hot temperatures.
ANd what do you mean by slide down? Slide down to DVD slot one or two?
If you need to get to the bottom one, hold the eject button.
Posted Mar 27, 2007 · 01:42 UTC#5
I'm not sure, but try Eject and RESET and let go of reset while still holding down EJECT button for 2 seconds. This did it for me.
Posted Mar 29, 2007 · 04:56 UTC#6
Ok, let me explain it again sorry. I live in Tucson Arizona, gets hot as heck down here. In the morning, it is nice and breezy. When I push the open button the screen will slide down in the morning. In the afternoon it gets blazing hot here, and when I start my car and try to push the open button the screen won't move. You hear the click sound but nothing happens. At night time I go out and it is nice and cool here at night. When I go out at night time around 9, when I start the car and push the open button the screen will slide down again. Any help here will be appreciate. Thanks.
Posted Mar 29, 2007 · 04:58 UTC#7
YEar make and model of the vehicle. And did you do what jimmy suggested?
Posted Mar 29, 2007 · 04:59 UTC#8
I have a 2005 Acura RSX. Which eject button? Do you mean the one behind the screen or the one that says "Open on the screen." Where is the reset button?? Sorry about the questions.
Posted Mar 29, 2007 · 05:18 UTC#9
Reset button is the indentation next to the joystick on the left side. He means the open button. Type S or no.
Posted Mar 29, 2007 · 07:10 UTC#10
not a type s
Posted Mar 30, 2007 · 13:49 UTC#11
tried the reset button and open button. Didn't work. Any other suggestions.
Posted Mar 31, 2007 · 01:35 UTC#12
Try adjusting the D! a dot higher in the dash opening, or file off about 1mm of the dash fascia opening under the head unit. Heat may be causing the dash pieces to expand, and, if the D1 is in just the right place, it might hang up on the way out.
Posted Mar 31, 2007 · 12:50 UTC#13
Another thing to try as a test to see if the D1 is getting tweaked.
Pull the D1 unit out of the dash slot about 1/2 way or so. (this should relieve and pressure buildup from a tweaked dash)
- Test the operation in the AM, based on your above post things should work fine.
- Test the operation around 1:00 or ? to see if it NOW works. If it does you have a tight install and it's getting tweaked as the dash heats up.
Just an idea
Posted Mar 31, 2007 · 16:27 UTC#14
Astroglide it.
Posted Apr 03, 2007 · 19:57 UTC#15
Exact same issue here....I called Pioneer today and they said that they were only aware of the N1 and N2 having this issue, not the D1. I just submitted the service request and I will post the Pioneer response here.
Posted Apr 06, 2007 · 17:54 UTC#16
Dear Pioneer Customer:
Thank you for contacting us about the problem with your Pioneer unit.
The model number you have listed is currently factory repair only. We have listed below Pioneer's address.
Carefully package the product, prepay, insure, and address it to Pioneer Electronics. Be sure to include a copy of your purchase receipt if your unit is within warranty and a description of the problem
you are experiencing.
Pioneer Electronics Service, Inc.
1925 E. Dominguez Street
Long Beach, CA 90801
Again, we thank you for contacting us about your Pioneer product, and we look forward to your continued business. If you have any questions, please reply via e-mail, or call (800) 421-1404, Monday through
Friday, between the hours of 6:00 AM and 4:30 PM Pacific time.
Gee....thanks. :-(
Posted Apr 06, 2007 · 23:56 UTC#17
There is another Pioneer service office in OH. I sent mine in last week. They are looking at it now and I should know the cost/problem by Wed of next week.
Maybe the OH office is less busy then the CA
Cheers :lol:
