Avic f700BT EW - TMC problem
By tkargul · Jan 29, 2014in Problems/Troubleshooting💬 4 posts👁️ 2,051 views
Posted Jan 29, 2014 · 09:55 UTC#1
Hi everyone,
I need Your help, I have problem with TMC not working on my device F700BT. I try to add some mod to sys.txt in Primo etc .. It doesn't work!,
I scan com ports in TEST mode to find out  com port where TMC signal is, but program hasn't  find any COM ports with TMC signal
so my question is:
Do I need ANY special antenna to TMC working on my device?
Posted Jan 30, 2014 · 11:26 UTC#2
OK, I've scan COM ports again in Test mode with GNS TMC.exe, and I found TMC signal at COM port 4 ;)
When I run GNS TMC.exe (not in Test mode) but in normal mode from avic menu-  access to this port is restricted !
I am trying do run TMC in iGo Primo, but in the same time I have running standard iGo (btw. in iGo I also don't have any TMC, only scanning frequencies)
so
How to release COM port 4, THAT IGO Primo has access to it
edit:
I have on my F700BT this soft : AVIC Net 2.0 EURO VERSION: http://avic411.com/index.php?/topic/32763-avicnet-21-for-avic-f-series-working-obdii-updated-041812/
Edited Jan 30, 2014 by tkargul
Posted May 26, 2014 · 20:53 UTC#3
Hi
There is simple way to bypass iGo using COM4. In SYS.TXT in iGo folder file add:
[tmc]
source="gns"
port="COM,8"
Restart system and igo will set igo TMC port to COM8, by the way not used. Now COM4 is free:))
To be sure it will work with your Primo or other NAVI add in SYS.TXT in PRIMO folder:
[tmc]
saved_config_available="1"
saved_config_classname="GNS_GPSTMC_SOURCE"
saved_config_portname="COM"
saved_config_port="4"
saved_last_tuning_mode="1"
auto_tuning="1"
Have fun
Edited May 26, 2014 by konick
Posted May 27, 2014 · 14:22 UTC#4
Sorry
BUG DO NOT CHANGE SYS.TXT in igo. It blocks port for BT parrot. Found this when fixed avic in car & tried connect phone.
Sorry once more.
