Very interesting.
Good to hear! I encourage you to explore and tweak more. Let us know what else you find. Thanks for sharing
Ill have more time this weekend to play around with things. What im thinking im going to start doing is making a skeleton winterboard theme. Within that theme will be all the images and image locations you can modify. All we will need to do is go in and change the images to what we want ( keeping them in the same size ratio ) and then drop the theme folder in winterboards theme folder.
You can have multiple themes in winterboard and all you will need to do is select the one you want and respring your device for it to show up. This way the stock images can stay in the app radio app, instead of replacing them with modified images (like I did above)
Ill keep you guys posted
@DDub420 - any news on this? I got some stuff changed up using ifile, but obviously if you could create a less time consuming way to switch everything up that would be awesome.
