backup camera operation
By docquinton · Feb 18, 2014in AppRadio, AppRadio 2, AppRadio 3💬 4 posts👁️ 1,641 views
Posted Feb 18, 2014 · 03:49 UTC#1
So I bought me a backup camera for my car to go along with my x5500bhs...however I cannot get the freaking thing to display in rear camera mode. At first I thought it was the camera, but when I switch the source to AV I can see the camera perfectly.
I've read as much of the info on these forums as I possibly could to no avail. I tried all combinations of switching the camera polarity setting(battery ground off) along with the rear camera option in the source menu( rear view off/on) and nothing seems to work.
Is it possible that the micro bypass affects it in any way? Ive also gone into appmode to trigger the parking brake warning screen and press ok hoping that was the answer but nope didn't work. Please help if you can. Thanks.
Posted Mar 03, 2014 · 19:35 UTC#2
Hi! I have a bypass and it doesn't affect rear cam at all!
Please specify what car do you have and how camera connected to carstereo?
Usually you should have a wire that connected to backlight lamp and to the responsible wire on carstereo. And when back lights on - you have a signal that turns carstereo to rear view mode.
Posted Mar 04, 2014 · 13:34 UTC#3
Do you have your (orange, I believe) trigger wire hooked to something that either goes to power or ground when the vehicle is put in reverse?  And if you do, check your settings.  There are three options for your trigger wire.
Posted Mar 10, 2014 · 05:43 UTC#4
Sorry guys, have to admit I've been an idiot. I somehow overlooked that there is a 'dedicated' input for the rear camera in. I was unaware of this and plugged my camera into the video in port. :wacko: So i'll try to install it again in a few days. Thanks.
