Navigation DVD won't eject, display dead
By keith48 · Feb 27, 2007in Problems/Troubleshooting💬 3 posts👁️ 976 views
Posted Feb 27, 2007 · 23:29 UTC#1
This unit worked fine until about a week ago. I cannot get my nav DVD to eject and the display is totally unresonsive. When I turn it on, it says "Navigation System is Starting Up," but then it goes black (still backlit) and the display nor any of the buttons on the display will work. I can still use the iPod and XM modules with no problem, but no display. PLEASE help. i bought this unit off of eBay so there is no warranty. Thanks!
Posted Feb 28, 2007 · 00:02 UTC#2
Sounds like it might be flex cable. Sometimes, to help isolate the problem, you can adjust the position of the screen using the +/- keys, and in some cases, that can cause the screen to come back on. Sometimes it doesn't. If it works, you know for sure you have a flex cable issue.
If it turns out it is the flex, you can have Pioneer fix it for free. They had to see my receipt, but I was out of the warantee period and they did it for free. I dunno how you would go about doing it with yours, but it might be possible.
Posted Feb 28, 2007 · 12:30 UTC#3
Adjusting the tilt of the screen has done nothing. Thanks for the input. Any other ideas out there? Thanks in advance!
