F920bt, problem with camera view
By Aethis68 · Feb 18, 2014in Problems/Troubleshooting💬 2 posts👁️ 889 views
Posted Feb 18, 2014 · 19:23 UTC#1
Hi all!
I have a problem. I just instal a rear view camera in my car and i have 2 problems.
1-the rear view don't come automatically, it's normal? I dont find anything in the manual guide.
2-when i Start the Pioneer, the screen is on the camera view and i can do nothing! I must disconnect the Pioneer.
Someone for help?
I have the last version of update, no custom.
Edited Feb 18, 2014 by Aethis68
Posted Feb 20, 2014 · 20:54 UTC#2
In settings, camera there is the option to change the polarity. Yours must be set the wrong way. If you can get to this screen then change it, if not press the reset button to turn the camera off then go into camera and set again. If you reset then you may have to put some settings back to how you want them.
I think it is to do with whether the feed from your reverse wire is positive or gnd when the car is in reverse.
I was messing with this setting when I ended up in the same situation as yours.
