How does one get the wires out of the plug in order to move it to another hole? I've done all I can think of short of cutting the plug open..
Thanks.
Thanks.
There is a video either here or on You Tube that shows how to pull a connector apart. There is usually a small tab sticking up that prevents the wire from coming out the back and that needs to be pushed down. I have several sets of jeweler's screw drivers and one will fit in beside the wire and then compress the tab. If you use a magnifying glass you can see where it is and then just pull it out.
