X930 wrong firmware
By whodat90 · Mar 05, 2014in Problems/Troubleshooting💬 7 posts👁️ 1,687 views
Posted Mar 05, 2014 · 02:12 UTC#1
So I'm a colossal anus and tried to update my x930 with x940 firmware, whcih mostly bricked it.  Does anyone have a backup of the x930 files?
Edited Mar 07, 2014 by whodat90
Posted Mar 05, 2014 · 18:55 UTC#2
Are you extracting the files from the ZIP file or just putting the zip file on the SD Card?  It sounds like its not seeing the files.  Thats probably why you would get a ---.---- instead of a ucom number.
The 5.1 firmware needs the Navteq update T1000-20495.  Are you sure that is the Navteq you used to update before?  If it's not then maybe you need the 4.6 x940bt firmware.
You can also call pioneer customer support and they will probably help you.  They have helped me with my firmware and iphone 5 kit problems.
Edited Mar 05, 2014 by IIMacGyverII
Posted Mar 05, 2014 · 22:16 UTC#3
I'm a moran
Posted Mar 05, 2014 · 22:41 UTC#4
Make sure the SD card is formatted in fat32 or fat16.  No other filesystem format.
Do you have a PC you can try to put the files on from?  Small chance but it might work.
try calling them, i sat on hold for 5 minutes the first time and 20 the second but they helped me both times.
Posted Mar 06, 2014 · 22:27 UTC#5
i'm stupid
Posted Mar 06, 2014 · 22:49 UTC#6
Still stupid
Posted Mar 07, 2014 · 02:44 UTC#7
 I found the user folder here http://www.4shared.com/file/rvUcjX7j/File_structure_and_USER_folder.html and copied that to my avic, now most things work.  Updated to firmware 3.1 and then reapplied my 2013 map update and all is well.  Rear speakers didn't work at first, but that turned out to be related to an amp failure.
Edited Mar 10, 2014 by whodat90
