AVIC-N3 Question
By darinb123 · Feb 28, 2007in General💬 3 posts👁️ 1,181 views
Posted Feb 28, 2007 · 07:58 UTC#1
I was considering this unit for navigaton in my 05 GMC Sierra 2500HD truck..... I like my Bose factory radio the way it is. I like the large screen and the fact that I can mount it in the lower opening in my console. When I dont need it the screen is safely out of the way and the faceplate is removable and maybe less likely to get stolen.... My question is: Can I use one of these units without the stereo part??????? I'm just wanting it for navigation purposes, no dvd's or stuff. I could care less too even hear voice promps either. Our local stereo shops aren't able too answer this, so I thought I would see if one of you guys could perhaps. I thought this would be a simpler install since so many of the wires won't even be hooked up per say. Thanks, Darin
Posted Feb 28, 2007 · 10:21 UTC#2
Of course you can, just need to hook up power, ground, the gps antenna, VSS wire, and reverse if you ever plan on adding a camera. Seems like it would be convenient to get the voice prompts and stuff too though
Posted Feb 28, 2007 · 18:00 UTC#3
Thats true.
However, it might be a little much if you're using it just for navigation! I would suggest other units, but I think the N-series is the only one with a retractable screen.. I guess if you can afford it, do it!
