SD card video on Z150BH
By joshehulbert · Mar 17, 2014in General💬 4 posts👁️ 2,224 views
Posted Mar 17, 2014 · 02:07 UTC#1
I just had a z150bh installed about a week ago and after a couple trips to the installer everything is working as expected - navigation, sirius/xm, iPhone connectivity, rear display and backup camera. I picked up an SD card and loaded a bunch of music on it - works great. I'd like to load some videos on it as well for my son to watch on the rear screen, but try as I might I can't seem to get the videos in a format the 150 likes. I've followed instructions on a couple posts and looked at the specs for video in the pioneer manual, and I sure thought I had Handbrake setup where it needed to be, but any video i try off the SD card gets me the same message that the video can't be played, check the documentation for supported formats.
Has anyone had luck with Handbrake on Mac (or another application for that matter), and could you share the settings you used? Thanks!
Posted Mar 17, 2014 · 22:26 UTC#2
I was able to get this going - two things to note. One, the correct settings in Handbrake seem to be:
MP4 video, MPEG-4 FFMpreg video codec
Framerate same as source
Constant Framerate
Average bit rate 2500kbps
Audio AAC ffmpeg stereo
Picture 400x240, anamorphic none, don't maintain aspect ratio, modulus 16, auto cropping
Now the problem is, this displays fine on the front screen... but not the rear. It sounds like perhaps rear display of SD card video isn't possible in the z150bh? Can that be?
Posted Apr 13, 2014 · 00:48 UTC#3
These settings worked great. First settings I've used that had the SD videos show up on the screen. Thanks. About your question:
pg. 169 in the ops manual stated that USB and SD video will not go out to the rear displays
Posted May 12, 2014 · 02:11 UTC#4
hmmm i must be doing something wrong, i used those settings and the video is very pixilated. Any idea as to why my video is comming in all funky?
