I attempted to update my nav software on my avic z140bh. I followed the instructions to a tee up to the point where i had to select "System uCom Write" i inadvertently pressed System uCom all Write. When i attempted to stop this it continued to write. Eventually i got an error message. I tried to remove sd but was unable to open screen. I removed battery cable and then reconnected but to no avail. Then the unit went black. I have not been able to revive it. I just checked fuse at rear of unit; it is o.k. Any and all suggestions welcome re: unbricking or removal of sd card. Thanks
need help resetting avic z140bh.
I had a bit of trouble opening the screen when I did my update. Did you try holding the open button continuously as the unit reboots?
Do you have any updates on this?
Any pdates on this? Mine is bricked after update as well.
Out with the old... Couldn't find any answers or get anything to work so I pulled the Pioneer and went with a new unit. I'll keep the Pioneer around for a little while to see if I can come up with anything, if I can't then to the trash it goes.
Jason
I'm looking for an answer to this issue as well. Anyone...?
No need to spam this all over the place. Not going to get an answer any faster.
Whatever...
This guy can fix avic's and can help...
Whatever...
You keep posting this link all over the place and the link is dead. Your guy no longer exist.
