Need help with Z110 BT
By Bigmikewsc · Mar 23, 2014in Problems/Troubleshooting💬 3 posts👁️ 778 views
Posted Mar 23, 2014 · 15:42 UTC#1
Just bought a used truck with Z110BT having trouble all the settings are grayed out and I can't change anything. Any help would be appreciated.
Posted Mar 23, 2014 · 19:52 UTC#2
Try setting the parking brake. If that doesn't do it, probably the parking brake sensor is not correctly installled, or the parking brake bypass is not correctly wired. Plenty of threads on this and a few Youtube vids. Make sure you follow the Z110-Z130 instructions it is slightly different on the Z140 hardware
Edited Mar 23, 2014 by RonS
Posted Mar 24, 2014 · 10:16 UTC#3
Man thanks so much set the brake a bam everything works
