Pioneer AVIC N3 birds chirping sound effect out of front speakers
By vigman · Mar 24, 2014in Problems/Troubleshooting💬 2 posts👁️ 2,620 views
Posted Mar 24, 2014 · 04:14 UTC#1
Hello,
I tried searching  and found nothing of substance...
I just installed an N-3 in a 1998 Expediition  So I could have GPS and great audio...
The unit is made up of bits & pieces but all of it works...
The "brain " was off E bay..same with the head...
The head needed a new ribbon & screen ( backlight was out )
Everything worked as it should ( on the bench ).
In the car..
#1 Problem, the car thought is was traveling 90 degrees out from actual.
So on the display, it showed I was drifting...  A reset & learn fixed that..
#2 Problem, I have a E brake line connected to ground ( and the screen bitches about that ) ...
#3 Problem, But this one has be confused...As I'm listening to my I pod ( via AV input )
The first time this happened , the car was  is in motion...
The audio mutes.. and I hear tweeting birds for about 4-5 seconds..
( no I'm not off my meds and  it's not an oscilation.. it's a sound effect )
And from a startup of the unit.. if I hit the NAV menu.. it will do it....
Help??
Mike
Posted Apr 01, 2014 · 13:07 UTC#2
According to Pioneer.... Via the HOME page, you can attach a " factory " sound to your home location. Mine had "Chirping Birds "... I selected "no sound" and still got the BOIDS.... so now I selected church chimes.. and see if that sticks....
