Hey guys I connected the AXXESS ASWC-1 interface module according to the instructions and tapped into the correct wires. Its not recognizing it. Maybe its not recognizing the radio since its a new release?? The vehicle is a 07 Chrysler Aspen Hemi
AXXESS ASWC-1 with 8000NEX
FYI, The ASWC-1 worked perfectly when I installed it in my Mercedes SL550 with the 7000NEX. I'm sure the interface protocol is the same as the 8000. Must be something about your wiring or installation. What are the lights doing on your module? That confirms that your car is talking with the ASWC-1. See the instructions for details.
As soon as I plugged it in. It starts recognizing it with green flashes. Then red. Then I hear the volume going down. And then it goes to flashing slow red lights. Doesn't go to steady.
I know I am tapping into the right wires.
Never mind I got it. I wasn't pressing volume up on time. I was waiting for it to stop flashing. Duh.
Which input did you guys use to connect to the back of the pioneer unit? There isn't anything specifically mentioning steering wheel controls so i'm not sure which to utilize?
It would be a 3.5mm jack.
Yeah there was more than one. Figured out it was the one that says wired remote
