My thoughts on Nex8000 and iPhone 5s
After about a week I've had some time to play with the 8000. One thing I have to say is to really understand what you have and it's features, you truly have to read the owners manual.
Some comments and questions I had that others have helped me with or I found in the manual.
Map zoom pinch and zoom.
Works we'll, first in the settings you have to set your desired zoom, close far, normal. Works pretty good after you set to your liking. Would be a little better if you could set it in increments like I could on my Z2.
Map color. Not day/night setting.
For me I set the map background to a light green, otherwise the white streets blend in too much with the map background and u can barely see the streets. Adjust that color to your liking and boom it's fixed, forget about the default.
I've been testing the routes for navigation with the built in nav, vs using my iPhone separately with google maps and Navigon on my iPhone, routes come up good.
Love having the live traffic, speed cameras warning too. I turned off the audible over the speed limit warnings, but left the visible on.
I also like the alternate routes it prompts you with as your driving, you can disable this in your settings, if you don't like it.
A nice upgrade from z2 is the ability of voice navigation, volume adjustment and that it doesn't interrupt music to speak.
The added ability to search intersection is sweet, my first pioneer unit had that, my z2 didn't, it's great to have that back.
Bluetooth pandora, sometimes it won't connect the app on my phone unless turn off Bluetooth on my phone, and then turn it back on and all is well.
If I start pandora on radio. It forces you to respond on the phone to allow it to work, can be annoying.
What I don't understand is that sometimes it does connect and play pandora even though the app isn't open on the phone at all.
Sound system definitely sounds better playing iPod, sdcard audio, than using pandora or aha radio. I change the audio settings for Bluetooth vs connected/wired eq. Easy to adjust though which is nice, eq is one touch away in each source.
One other thing I very much like is that, you can adjust incoming voice call, I have some friends who are loud and some who speak low, just raise or lower the volume adjust how I can hear the caller.
If you don't read the manual, and make a bunch of adjustments to your preference, your experience will not be as great as if you did some reading.
Haven't tried apps yet, my cable is due in today.
