8000 Nav Voice Volume low
By CuznVinny · Apr 07, 2014in NEX Series💬 21 posts👁️ 6,448 views
Posted Apr 07, 2014 · 20:45 UTC#1
Anyone else think the nav voice volume is to low? I have mine at 100% and its LOW, you really have to listen. When I adjust it anything between 50% and 100% sounds the same. It like 50% is max
Posted Apr 07, 2014 · 22:55 UTC#2
I actually have mine set to 30% that's low but 100 is loud as hell
Posted Apr 07, 2014 · 22:58 UTC#3
I find mine to be quiet loud also and have turned it down, I was using it yesterday and it seemed good for a while and I think that when I stopped for lunch it became quite a bit louder after the restart, perhaps try adjusting the regulator volume control and changing sources and see if anything affects it...
Posted Apr 08, 2014 · 01:28 UTC#4
Mines at 23%
Posted Apr 08, 2014 · 02:40 UTC#5
you guys using the TTS voice, or the Dave and Amy? If I switch back to Dave or Amy, it is louder and it adjust full range, but not what I would call loud as hell.
Posted Apr 08, 2014 · 10:21 UTC#6
I was on Amy I will see how the TTS selection works
Posted Apr 08, 2014 · 18:08 UTC#7
I have it set to Amy and my volume is at 40%. I had it at 24% before and while driving down the highway jamming (quite loudly i might add) to some FFDP, she tried to give me directions and i couldn't hear her at all (as the mute level wasn't muted enough). So i adjusted mine back up to 40%. I may re-evaluate my mute mode and see if that helps (maybe like completely muted vs just a lower db level). However i really do wish we had the option to pause the audio while giving instructions and then un-pausing afterword, but i don't see that happening, like ever.
Posted Apr 08, 2014 · 19:08 UTC#8
Ok some tried TTS volume at 25% while my music was at a comfortable level and the TTS was volume was plenty for me. As far as music pausing for driving instructions, no thanks my z2 did that and I hated it. I guess we all have our preferences but mine sure is not to interrupt the music for directions.
Posted Apr 08, 2014 · 19:20 UTC#9
For Music i don't care. I'm with you. But when listening to an Audiobook and it mutes so she can give me the directions i'd prefer a pause/unpause. I'll just have to live with the mute i guess :)
Posted Apr 09, 2014 · 02:25 UTC#10
Also do you guys have the sped sensitive volume turned on. This may not work with the navi voice as road noise increases as it works for music.
Posted Apr 09, 2014 · 12:47 UTC#11
Really what they should do is have an option to have the guidance volume tied to the overall system volume, if I have the radio loud do to lets say the windows down I would like the voice louder...
Perhaps I will try the auto volume and see if that works
Posted Apr 09, 2014 · 19:58 UTC#12
I know you guys are aware of this but just in case someone who isn't sure where exactly it's at, they can follow this link below:
https://www.youtube.com/watch?v=PJU7J0dZAdY
Skip to 55 seconds into the video.
Posted Mar 21, 2016 · 22:56 UTC#13
Volume is very low, difficult to hear when driving on the highway.  I've called Pioneer support approximately 7 times.  I bought as a refurb over a yr ago, and refurbs have a 90 day warranty.  I should have sent it back for testing.  Did you ever figure out how to fix, CuznVinny?
Posted Feb 12, 2017 · 18:25 UTC#14
For anyone having trouble with the GPS volume being too low it is caused by the Axxess GMOS-LAN-02. You need to adjust the volume setting on it.
Posted Feb 12, 2017 · 20:17 UTC#15
I finally figured this may be the culprit, just haven't had a chance to go back in the dash.  Thanks for the update.
Posted Feb 13, 2017 · 20:56 UTC#16
Both the door chimes and the radio volume itself can be adjusted separate. Adjust the chimes with the driver side door open, close the door to adjust the volume of the gps.
Posted Feb 13, 2017 · 20:56 UTC#17
Posted Feb 14, 2017 · 15:16 UTC#18
You're the man, Kyle!  Thanks!
Posted Feb 19, 2017 · 18:11 UTC#19
Got a chance to go into the dash yesterday and adjust the gmos volume.  I can confirm this solved my problem which I've been dealing with for 2 years.  Thanks again to kylek567!
Posted Feb 20, 2017 · 00:19 UTC#20
I'm glad I can help you!.
Posted Mar 14, 2018 · 23:21 UTC#21
Any other causes I adusted the volume on the gmos 01 and the volume is unchanged also my hands free calling is as low as the voice Navi.... Please help
