Reverse wire for WRX?
By Rodge · Feb 28, 2007in Vehicle Specific Wiring💬 4 posts👁️ 1,690 views
Posted Feb 28, 2007 · 23:59 UTC#1
Almost done with my install... But I can't find any solid info on where the reverse wire is for an 06 WRX. I do not have a power tester so I can't look for the positive reverse light.
So if anyone knows where to find the reverse light for an 06 WRX let me know..
thanks
side note: If I have my rear cam ground, parking brake ground, and secret wire all linked together, spliced off of the ground on the wire harness, where do I ground that?
Posted Mar 01, 2007 · 01:27 UTC#2
Reverse Light brown/yellow + passenger kick, harness to rear
As for the ground goes you can use one of the screws that holds the avic in the dash for ground.
Posted Mar 01, 2007 · 03:50 UTC#3
thanks dude....
For the grounding, this is what i did:
connected the "black" on Z1 harness to the "black" on the after market harness which connects to my car. IN BETWEEN that connection, I have spliced in the (secret wire, parking brake, ground for my rear cam).
Is this correct?
I guess what I'm saying is I did NOT ground these wires to a screw, I simply just used the ground from the wire harness.. Will this work?
I guess we're about to find out, Cuz I'm starting it up in 10 minutes for the first time
Posted Mar 01, 2007 · 13:22 UTC#4
Should work just fine.
