I have a nex 8000 and a samsung galaxy s5, have all of the required cords and adapters but cant get the app radio to work properly. I have been able to get Pandora, aha, and mirror to work but when I try to get apps on the screen all I get is a black screen with a white dot and it won't connect but then it will mirror my screen with no control from the radio screen, when I touch it I get a x in a red box with a finger pointing to it. I have seen posts regarding Iphones but none about Android. Has anyone had luck with androids.
android smartphone using app radio
Could this be caused by the USB port you're using?
With a quick scan of my 4000nex documentation it appears the Android devices only use USB2 whereas the iPhones use USB1 or USB2 depending upon the connection method.
I have the Usb connected that way. Ipod Usb 1 and smartphone in usb 2
5 to 11 pin adapter is needed for Samsung S4 & S5 models.
I have the adapter
Have you contacted Pioneer support about your issue?
If so, what was their response?
I have contacted pioneer and the got the app radio going. I'm sweet now
What did you have to change, just so we all know?
When setting up you will get a black screen with white dot on radio and phone. Touch the dot on the radio and keep following the dot as it moves around the screen. Its like a calibration.
Hi
I'm just checking what cables you used for Samsung Galaxy to work?
I'm considering this unit and I'm a bit confused between the mirrorlink and the appradio settings and connections.
Did you use the Android MHL adapter to get it working via AppRadio?
Is AR better than ML?
Cheers
Hi
Cheers
Yes I'm using the mhl adapter that doesn't come with the included cables. I haven't really tried ml since I've been able to get AR to work but before that it just mirrored the phone with no control on the radio screen and I think that's the case, but there is appradio unchained which requires the phone to be rooted. I will check it out for sure shortly and if I get a different result I'll let you know as far as ML.
Hello starkey,
I am also considering the NEX 8000 and am also a bit confused (which is easily done). Are you getting full functionality of AppRadio with your S5 and did you have to root your phone to do so? My only concern is that Pioneer does not list the S5 as compatible, but I do realize that might be because it has not been tested yet. Any input is very much appreciated.
