8000 NEX Bluetooth issues
By Beezle · Apr 18, 2014in NEX Series💬 16 posts👁️ 6,008 views
Posted Apr 18, 2014 · 21:49 UTC#1
I've had the 8000 in my Tundra truck for about a week now. Generally quite happy with it. Very excited about the Carplay announcement.
I am however seeing issues as one would expect with a new product. One issue in general has been Bluetooth connectivity.
If things work, they are fine, but I find that the auto-connect is fairly unreliable and I usually have issues getting Pandora or aha started up via BT.
Anyone else seeing these? I assume this is just a thing needing love in the coming firmware release(s) and knowing I'm not alone would help in that regard.
Posted Apr 18, 2014 · 22:31 UTC#2
Sorry to hear this. Haven't experienced this.
Posted Apr 18, 2014 · 23:55 UTC#3
Had another interesting issue today in that when I started up Pandora from the 8000, music started coming from the phone, but not the 8000. The settings were all appropriate.
Then I tried Bluetooth Audio and that worked. Playing back Pandora sound, that is. Then back to Pandora on the 8000 and it worked again.
This is an iPhone 5s with iOS 7.1 installed.
Posted Apr 19, 2014 · 12:28 UTC#4
I'm running an iP5S with 7.x and haven't experienced this. It does take a little longer than I'd like for the unit to connect to the iPhone when I first turn the car on but when it does, never had an issue.
Edited Apr 20, 2014 by Kstryker
Posted Apr 22, 2014 · 23:17 UTC#5
I am continuing to have issues with Bluetooth and with Pandora and aha if I use the AV adapter/lightning connection OR Bluetooth.
This thing is too buggy.
Posted Apr 22, 2014 · 23:40 UTC#6
I'm using the lightning adapter. App radio is horrible. Not worth listening to music when opening the car media app in app radio when I can go to ipod1 source.
Posted May 03, 2014 · 12:35 UTC#7
Finally got this resolved.
The gist of it is the issue was the phone.
I fooled myself into thinking it was the 8000 by testing using another phone just at the edge of the WIFI at my house, so a very poor connection made it appear I was having bluetooth issues.
My phone was tested once and thought fine, but I had it tested again and it failed. Not certain if it was software or a bad bluetooth card in the phone, but in any case the phone was replaced and everything is working fine now.
Happiness achieved.
Posted May 04, 2014 · 06:01 UTC#8
I'm haveing a problem where the 8000 wont let me use the siri voice commands with out manualy going into my Iphone 5 bluetooth settings and reconnect the bluetooth connection again even though it already says it's connected. Also is there a way to give permate  perrmission for a program to have access to the 8000 system for example Pandora or am I doomed to have to hit allow every time I choose use a mode on the 8000?
Posted May 04, 2014 · 11:12 UTC#9
I haven't had any problems with Bluetooth, I've used the radio for about 2k miles now, and no you must keep hitting allow for those permissions
Edited May 04, 2014 by tekki
Posted May 05, 2014 · 06:04 UTC#10
I think I might have found a solution to my Bluetooth problem, I just make sure that my iPhone is hooked up to the 8000 unit before I turn the engine in my vehicle on. I hope this is a permanent solution.
Posted May 05, 2014 · 21:56 UTC#11
I had a similar issue but it was because I didn't perform a factory reset before I started using the unit. Once I used a paperclip on the reset button all my weirdness went away.
Posted May 06, 2014 · 03:37 UTC#12
Ok... Of course after I posted my reply my bluetooth started going crazy... it's now not auto-connecting, I have to manually re-connect it even though the option is set to ON.
Posted May 06, 2014 · 03:42 UTC#13
Beezle said it was his phone that was the issue. He replaced the phone and it works fine. Maybe it can be your phone??
Posted May 12, 2014 · 22:15 UTC#14
That did work for me. But we were not certain the issue was phone vs. software.
If you are having these issues I did, I would recommend backing up your phone, then restore the phone to the plain iOS, set it up as you need to then try that. If you sync contacts, etc. it isn't too hard to put everything back without restoring from a backup.
If that doesn't work, I'd take the phone in and have it tested. But I would guess that cleaning up the software on the phone will actually fix it.
Posted May 12, 2014 · 23:10 UTC#15
Things worked great for awhile but now it is back to not automatically syncing with the Bluetooth on my iphone 5 and the 8000. It shows on both the phone and the 8000 that there is a connection but I still have to manually re-connect the device to work. Does any one know if this might be happening because I have to many things hooked up to Bluetooth?
Posted May 13, 2014 · 02:02 UTC#16
Do you have multiple Bluetooth devices Paired with the NEX?
If so, then it sounds like you're describing what azjack discussed in his thread on Bluetooth Pairing:  http://avic411.com/index.php?/topic/38779-bluetooth-pairing-priority-on-avic-8000-and-possibly-all-nex-devices/
Edited May 13, 2014 by highctech
