NEX 6000 with backup camera
By tractors4u · Apr 20, 2014in NEX Series💬 8 posts👁️ 3,831 views
Posted Apr 20, 2014 · 12:55 UTC#1
I installed an NEX 6000 in my 2012 Jeep Wrangler Unlimited.  Everything is working great except my backup camera.  I'm using an iDatalink harness and the Maestro box.  On the HU the purple/white stripe wire is designated as the backup camera wire.  I connected the one from the HU to the iDatalink harness.  I installed my camera and connected the power wire to the positive wire of my backup light on the Jeep.  I'm not getting anything on the HU.  What am I missing?  The Pioneer manual said to connect the purple/white wire to the wire of the vehicle that changes voltage when placed in reverse.  Should I have connected the purple/white directly to the tail light wire as well?
Posted Apr 20, 2014 · 13:08 UTC#2
I don't know about the idatalink, so the install may be different. However, generally speaking, the purple/white wire is the reverse sensing wire, attach it to the backup light also. Plug the camera's RCA (probably yellow) into the camera input on the NEX (I think brown, look at the manual).
Posted Apr 20, 2014 · 19:04 UTC#3
Hook up the wire from the tail light directly to the HU. That's what I did. I couldn't figure out why it wasn't working. Also you have to turn on the back up camera setting to on and to battery.
Posted Apr 24, 2014 · 12:48 UTC#4
Well this is embarrassing.  I did read the instructions, I knew where the RCA plug for the back up camera went, but some how or another in the 6 times I've pulled that head unit out of the dash I managed to plug it into the wrong plug.  I pulled it out yesterday and as soon as I saw it I knew what I'd done.  I also found out why people couldn't hear me on the phone any more.  The mic cable had gotten pulled out.  All is right with the 6000 now, except Appradio.
Posted Apr 24, 2014 · 20:28 UTC#5
app radio is garbage. point blank. i wont be using it.
Posted Apr 24, 2014 · 23:58 UTC#6
I think I will probably be returning it.
Posted Apr 25, 2014 · 02:15 UTC#7
App radio shouldnt be a main focus of the radio. I was stuck between the NEX and the Kenwood DNN991HD. But I wasnt waiting until May
Posted Apr 25, 2014 · 16:20 UTC#8
I can understand why this happened as I did the same thing, there is a yellow cable on the radio that is labeled backup camera.
