NEX-6000 3D Calibration
By bsmack · Apr 21, 2014in NEX Series💬 10 posts👁️ 2,588 views
Posted Apr 21, 2014 · 17:46 UTC#1
Has anyone had any trouble with the 3D calibration?  My sensor seems to think I'm always taking a left when the car is driving straight.  I've tried resetting the sensor a few times (all settings) and it doesn't seem to want to fix.  Anyone else running into this issue?
Posted Apr 22, 2014 · 15:53 UTC#2
The derp on the pioneer support line told me to relocate my antenna.  Reading the manual more closely, it looks like direction is gathered from a gyro sensor in the head unit, not the antenna.  I have plenty of connectivity where the antenna currently is (under a thin piece of plastic in the dash) so I'm not moving it.
Posted Apr 22, 2014 · 16:17 UTC#3
I've seen an issue when driving on roads that aren't on the map, it will randomly put you onto the closet road which is really weird.
Posted Apr 22, 2014 · 16:34 UTC#4
My issue is different I think.  I can be driving perfectly straight in 1 lane on the highway, and the GPS will think I took an exit and will try to put me on various side streets.  It's really bad.  When the sensor is in its "initializing" mode after resetting (guessing it's not being used) it works perfectly fine.  Kind of wish I could just disable the gyro all together.  Just doesn't seem to want to recalibrate at all, or gets stuck easily.
Posted Apr 22, 2014 · 17:00 UTC#5
I've done about a thousand miles of travel and navigation with mine, mostly central and southern NJ, a little bit of Staten Island and my GPS has been pretty spot on. One thing I noticed is that if I choose a car graphic I can actually pass a street before the Navigation does, if I chose the standard arrow it's perfect when driving so I set it back to the arrow.
Posted Apr 22, 2014 · 18:59 UTC#6
Would anyone be willing to do me a favor and reset their 3D calibration on flat/level ground while not moving?  When I reset mine and I'm completely stationary, the sensor thinks I'm turning left.  Just want to confirm it's just me.
Posted Apr 23, 2014 · 12:27 UTC#7
So I did another hard reset on the way home and it seemed to work on my 20 mile commute.  I spoke with my dealer and told him that I will continue testing until Monday, and if it's fine until then then we won't need a swap.  Hoping it keeps working because I don't want to open my dash again.
Posted Apr 23, 2014 · 18:48 UTC#8
Welp, it just looks like this particular unit has a habit of getting stuck.  The 2 lane highway I go on in the morning is quite bumpy for the first 3-4 miles, and it messes with the sensor.  Eventually it just gets fed up and sticks me going permanently left.  I'm upgrading to the 8000NEX, hopefully I won't have this issue.
Posted Feb 19, 2015 · 02:11 UTC#9
After reading all the problems with the nex 6000 gps, i wonder why pioneer is not addressing these issues with a update or something. I had to send my unit back because of the same gps issues, even tried a brand new antenna.
I hope the issue is fixed before the new unit is delivered.
Posted Feb 19, 2015 · 03:17 UTC#10
Have had my 6000NEX unit since Dec. Had it professionally installed. Only issue I have had is that one time the clock was behind by an hour, so my arrival times were behind as well. Then it "magically" corrected itself. Ha
Edited Feb 19, 2015 by huddy
