Caution message
By Sebas718 · Apr 27, 2014in NEX Series💬 10 posts👁️ 1,920 views
Posted Apr 27, 2014 · 15:55 UTC#1
"CAUTION IMAGINE MAY APEAR REVSERSED" message pops all the time, is it because of installation or something else? Has anybody encounter this issue? It has to be something with the camera because when I turn it off this message dosent appear
Posted Apr 27, 2014 · 16:06 UTC#2
I think this is normal. I could be wrong
Posted Apr 27, 2014 · 17:01 UTC#3
It's a black screen message that pops every 15 seconds, it's annoying. It can't be normal because this started happening recently.
Posted Apr 27, 2014 · 17:24 UTC#4
turn off Camera View in camera settings
Posted Apr 27, 2014 · 17:30 UTC#5
If I do that then my camera won't work
Posted Apr 27, 2014 · 18:41 UTC#6
Then something is not connected properly. Your camera should turn on when the car is in reverse and turn off when you shift out of reverse. This should work whether the camera setting is on OR off. If it only work when that setting is on, then something is not connected properly.
Posted Apr 27, 2014 · 19:33 UTC#7
Camera Veiw is the camera pop up setting that keeps the camera on all the time. If you want it just in reverse, turn off Camera View, and turn on reverse trigger.
Posted Apr 27, 2014 · 22:36 UTC#8
How do I do that?
Posted Apr 28, 2014 · 04:32 UTC#9
1. is the camera connected to the brown (REAR CAMERA INPUT)?
2. I found that I had to hook up the reverse trigger to the back of the unit. Theres a reverse trigger wire there.
Check if thats the issue. That was my issue
Posted Apr 28, 2014 · 12:06 UTC#10
as others have stated, turn off camera view... this is not for reverse operation.... long as you have camera plugged into brown port, camera input on and connected purple/white wire to reverse signal then shouldn't be an issue....
