F920BT Brick? No boot! No reading testmode from SD
By marx74 · Apr 27, 2014in Problems/Troubleshooting💬 11 posts👁️ 2,456 views
Posted Apr 27, 2014 · 19:23 UTC#1
Hi all,
I have a problem with the radio F920BT, during the update 5.00 in TESTMODE created a problem, because I deleted the folder PRG0 and do not know what to do. Radio launched again after turning the ignition switch and displays only the Welcome board and is so for a minute or maybe two (which is better in this mode works reversing camera but nothing else) and suddenly the radio resets after 2 minutes and chapel, dark screen and just shine buttons. Radio does not respond to the card insertion TESTMODE just like radio did not see nothing on the SD card. The tragedy needs help. Maybe someone fought with something like that? Please help ....
Does anyone know a service in Poland that would fix it?
Edited Apr 27, 2014 by marx74
Posted Apr 27, 2014 · 22:11 UTC#2
Just restore your backup.  You did take a backup... did you?
If not, is there a PRG1 folder?  it might have the files you need.
Posted Apr 28, 2014 · 04:44 UTC#3
I current do not have a backup, but it wrzuciłbym because I have some old year. Just like how I do not know how to get on to read from the SD card to enter into a service mode.
Posted Apr 28, 2014 · 05:30 UTC#4
Or is it some combination of keys? I remember that at some forum or somewhere on the internet I found once some key combinations of inclusion and passed this test mode.
Posted Apr 28, 2014 · 21:56 UTC#5
You need to have a PRG0 folder inside your USER folder.  If you don't, your unit will not work.
I have never heard of a key combination to skip something on the unit.
Posted Apr 29, 2014 · 06:21 UTC#6
Well, just how to copy files to PRG0? Maybe the CD is there a way? Or if I disconnect the battery for a long time and then react to the radio and call boot from SD?
I found somewhere a description of how to enter the test mode, but it does not work now:
To enter Service Mode: Let the device finish starting. Press and hold "Home" then press right,left,right,left,right,left then release "Home"
Edited Apr 29, 2014 by marx74
Posted Apr 29, 2014 · 18:57 UTC#7
Maybe someone has an idea how to flash the radio? There must be some way without interference inside.
Posted May 02, 2014 · 21:14 UTC#8
there is no person who can help?
Posted May 19, 2014 · 16:35 UTC#9
@marx74
If there is a FLG file directly within the USER folder the PRG1 file should start up the device.
Otherwise do copy the PRG1 folder rename it and past it within the USER folder.
The device should start up.
 Greetings John5
Posted May 22, 2014 · 19:23 UTC#10
@marx74
 Greetings John5
OK, But how to get to memory and create a folder PRG1? If you can somehow get to the radio from the USB or some way through the microSD card as there is no PRG directory?
Edited May 22, 2014 by VBLUE42
Posted May 23, 2014 · 19:56 UTC#11
Can someone toss to download the file PRG.FLG and PRG1.FLG?
