I get the disclaimer and hit continue. It then spins for a while then either says "cannot open the available map files with your license" or it goes right to the home screen. Also, the time and date are incorrect.
Posted May 07, 2014 · 11:23 UTC#1
what unit do you have?
try a factory reset
I tried multiple factory resets. It is a 6000nex.
Wow...are there map updates already?
Why do you say that?
No, there are no map updates and if the OP tried some sort of map update that would be the problem as they are obviously fake.
I called pioneer. They said it was defective and to return it. I got a new one installed last night and everything is working correctly. Thanks for the replies.
