Going from AppRadio 3 (SPH-DA210) to AVIC-8000NEX
By carloslaso · May 07, 2014in NEX Series💬 7 posts👁️ 2,773 views
Posted May 07, 2014 · 15:08 UTC#1
I just bought the AVIC-8000NEX and I cannot wait to install it but I have an AppRadio3 (SPH-DA210), I had the AppRadio2 and I just swapped the unit without additional wiring changes.
Do you think I would be able to do the same on the AVIC-8000NEX? Does it need special wiring? The setup I have right now has a switch that bypasses the handbreak and I already saw the thread with the software bypass. I have the steering wheel controls working on the AppRadio3 but nothing as fancy as what I have seen the iDatalink - Maestro seems to do.
Will I be able to do the same as before or the shops are going to try to charge me a lot of money to install it like anything I already have would not work? :o
Posted May 07, 2014 · 22:31 UTC#2
The plug looks the same to me. There are other models that the harness clip works fine with the 8000nex.
Posted May 08, 2014 · 05:07 UTC#3
They used only the new USB cable, I do not know why. I need to read the manual, the voices in the Pioneer map are driving me crazy, they are too loud, also I have to configure the app radio screen, the menu items are taking too much space.
btw, the software bypass worked.
Edit: nevermind, I watched the youtube videos  :shock:
Edited May 08, 2014 by carloslaso
Posted May 08, 2014 · 19:35 UTC#4
I switched from an Appradio 2 to an Appradio 3 using the same plug, it worked no problem.  I just switch from my Appradio 3 to the 8000NEX, and while the plug will fit, it is missing the VSS wire for GPS.  You may be able to get by without it, but I'm thinking GPS won't be as accurate.  I swapped mine out just to be sure.
Posted May 09, 2014 · 22:46 UTC#5
Which is the VSS wire ? I am new to this :oops:
Posted May 10, 2014 · 00:39 UTC#6
the radio has one and most vehicles have them. get your vehicle wiring diagram. it should tell you
Posted May 10, 2014 · 02:31 UTC#7
Vehicle speed sensor, I used the gmos-014 and it provided one for me, most wiring adapters will. Are you using an adapter, and if so, which one?
