VSS WIRE FOR 2006 Lincoln Zephyr
By Sabre3487 · Mar 01, 2007in Problems/Troubleshooting💬 5 posts👁️ 1,039 views
Posted Mar 01, 2007 · 21:57 UTC#1
Just curious if anyone knew where to tie into the VSS line on the 06 Lincoln Zephyr?
Thanks,
Burn
Posted Mar 01, 2007 · 23:21 UTC#2
My info says go to a wheel speed sensor. That's all no color or anything.
Posted Mar 01, 2007 · 23:37 UTC#3
I am in contact with some of the mechanic guys at the lincoln dealer, there has to be a better way to access this wire.
Anyone else??
Posted Mar 06, 2007 · 01:22 UTC#4
There is no speed sense wire on the new platform Fords. You dont need it anyway.Pioneer Navis work fine in learn mode. But if you want, Alpine makes a speed pulse generator that you mount over the rear wheelwell in the trunk.
Posted Mar 06, 2007 · 18:15 UTC#5
In the Zephyr the only way to get the pulse is to use one of the wheel speed sensors.
I will post wire colors for you. It is an analog sensor so you would tap into the pos side.
Burn
