Annoying Parking Brake Message
By dvarapala · May 22, 2014in NEX Series💬 5 posts👁️ 2,092 views
Posted May 22, 2014 · 04:07 UTC#1
When I installed my 8000NEX I permanantly grounded the parking brake input wire and then did the bypass. The bypass is working fine but every trip I have to click past an annoying message which says my parking brake input is not properly wired. I guess the bypass doesn't bypass the annoying nag screens. :(
If I go back in there and wire the parking brake input properly I assume it will a) get rid of the nag screen, and B) have no effect on the operation of the bypass.
Am I right?
Posted May 22, 2014 · 11:02 UTC#2
you didnt do the bypass right
Posted May 22, 2014 · 12:45 UTC#3
that happens to me every once in a while maybe 3 or 4 times in the last 6 weeks but it doesnt happen every time
Posted May 24, 2014 · 21:47 UTC#4
Famous-characters-Troll-face-Challenge-a
So while I had the console apart this morning to run some other wiring I went back and corrected the parking brake wiring also (i.e. instead of simply grounding it I hooked it up to the actual parking brake lead, just as Pioneer intended). After powering the unit back up and re-applying the nanny bypass, I threw in a DVD to play while I drove over to the Post Office. I'm happy to report that the nanny bypass still works and the "your parking brake is miswired" nag screens are gone!! WooHoo!!!!
Now if I could just get these AppRadio mode bugs fixed... :D
Posted May 25, 2014 · 05:37 UTC#5
:mrgreen: 8)
Edited May 25, 2014 by Shackleton
