Video playback via USB - NEX8000
By camar0rs · May 23, 2014in NEX Series💬 16 posts👁️ 8,843 views
Posted May 23, 2014 · 16:06 UTC#1
Is there anything to be aware of trying to play video from USB?
currently I have USB2 for android phone cable, USB1 has female adapter.  Only views music, other files get greyed out...
playback only available from USB2 ?
Edited May 23, 2014 by camar0rs
Posted May 23, 2014 · 16:27 UTC#2
you should be using android device on USB2. thats the designated port for your device. USB1 are for apple products. i have my iphone on usb 1 and a 32gb flash drive on usb2 and my video files work fine. what file format are the movies??
Posted May 23, 2014 · 16:29 UTC#3
looks like it appears it just cannot read video files from my PNY 128GB USB Drive... it says FAT32....   I put same videos on a Sandisk 4GB usb drive and played fine... bah!
Posted May 23, 2014 · 16:51 UTC#4
ok I figured it out.....  it appears the headunit will NOT let you have MUSIC and VIDEO files on same USB to switch between.... once you add music files, video files get inaccessible....
Posted May 26, 2014 · 16:01 UTC#5
hmmm.... now it appears this drive likes to crash the nex8000... very odd....   basically what it does now is tries to read then shortly after the unit reboots.... then says LOADING...........  and gets stuck....   no way to get out of it until USB remove and power cycle....
Posted May 27, 2014 · 01:55 UTC#6
That's not true. There's a button on the music timer on the left. A folder icon and you will see three options. MUSIC>VIDEO>PHOTOS. The HU automatically defaults to music the first time you put the SD card in.
Edited May 27, 2014 by drenyce311
Posted May 27, 2014 · 18:34 UTC#7
No, it definitely is fine with multiple types of files on one device, and USB1 and 2 are interchangeable.
I have a 120GB NTFS-formatted SSD on USB1.  Works fine.
Note that the NEX units are fairly restricted on what video formats they will play.  Specifically, WMV/H.264 and DivX are listed as "compatible", as is MKV/FLV (!)
Although not explicitly listed at least some some AVI files also work.
Specifically, AVI files encoded for XviD video with MPEG-1 audio appear to work; I've played those.
High-def MP4 video files will not play despite MP4 being listed as a valid format for audio and the subtype being listed (MPEG-4) by Pioneer as a valid decoding option.
Edited May 27, 2014 by tickerguy
Posted May 27, 2014 · 20:05 UTC#8
I have MPEG 4 movies on my sd card and they have no problem playing, they look fantastic.
Posted May 27, 2014 · 21:51 UTC#9
Playable file types (USB\SD) MP3, WMA, AAC, WAVE, FLAC, H.264, MPEG4, WMV, FLV, MKV
The manual also says that Divx files won't play via USB\SD
Posted May 28, 2014 · 00:32 UTC#10
May be a bitrate problem then.  They're VERY high bitrate in the cases I've tried, and they don't work.  They're also more than 2G in size.
Posted May 28, 2014 · 11:05 UTC#11
Are yours on and sd card or a USB drive? That could be the difference mine are all on sd card and just about 1.8 gig
Posted May 28, 2014 · 12:04 UTC#12
I haven't had any issues with sd card playback, just USB drive so far
Posted May 28, 2014 · 13:17 UTC#13
I checked format compatibility with an SD card.  I've not seen any difference between the two; if it will play on the SD card it will also on the USB-attached SSD in my experience.
Posted May 28, 2014 · 19:53 UTC#14
If the mpeg4 files were purchased in itunes store, they are protected. I got a program that removes the protection and now they all play on sd card and usb thumbnail, and ssd.
Posted May 28, 2014 · 20:00 UTC#15
No, they're not protected.
I'll do some more digging around on this, as I have a video production system here and can set up virtually any bit rate and encoding options that I want.
Posted Jun 12, 2014 · 03:39 UTC#16
Turns out it was (bitrate problem)
I took Handbrake to the original source and cut a MP4 with H.264 for the video codec at a size compatible with the head unit's display, and they play fine off my SSD.
Of course this means downconverting a lot of my stuff if I want to play it in the car.  Fortunately, most of the time I don't, and the few things I do (e.g. concerts and music videos) I'm as much interested in the music part as the video part if not more-so.
Edited Jun 12, 2014 by tickerguy
